You need to download all 8 parts to the same folder, then point WinRar at part 1. This will unzip all 8 parts to a single file named "New Bravo eLEARN.iso". This is an image file which you use to create a CD, using a program like "Imgeburn". Do not copy the .iso file to CD.
Once you've created the CD, eject it and re-insert it into your CD drive and the eLEARN interface should install via Autorun. This will also create an eLEARN icon on the desktop. Use the icon to start the program. As only the interface is installed on your PC, the CD needs to be in the drive whenever you use the program.
