Hi all.
My name is Karl. Im in Nottinghamshire.I have joined up to FF as I have a Fiat Stilo 1.9 multijet estate. I bought it with a heating problem, thinking it would be an easy fit. Boy did I get that wrong. The last owner obviously had a problem with it as the car is damp and smells bad. The climate control obviously hasn't been working for a while. Having read through some of the threads, I suspect a blown fan as there is nothing working. No heat, no blower. The only thing that seem a to work is the digital display.
I can't seem to find any resisters . Can anyone tell me if I need to remove the scuttle panel? And can anyone tell me if the centre console on a 3 door hatch will fit the estate.
Thanks in advance.
Hi, Welcome to the FF.
You don't need to remove the scuttle panel, the fan is located high up behind the right side centre console. 3 small screws hold the fan into the heater casing. You will need a means of holding the clutch pedal down while removing the fan.
