Not sure about the burning smell but when my last alternator failed it did exactly the same thing - basically the car just ran out of electricity and stopped working.
It's definitely not the alternator, as electrics are fine. I had about an hour wait on a dual carriageway (with no hard shoulder), so had the ignition on so I could keep the back lights on and power my fag-lighter tyre pump, which has a dazzling flashing yellow light - I put this on the roof. For half an hour I had dipped beam on, until I saw it and changed to sidelights. The electrics are still fine after this.
He said that if the turbo goes you normally get filthy clouds, not just a bit of a smell, as the oil is dumped into the exhaust. You also get over-running from the burning oil - it isn't doing this. The engine oil level is fine.
I'm hoping for a hose or EGR valve. If the EGR was stuck 100% open would that suffocate the engine due to lack of oxygen?
I haven't tried ecuscan yet, just about to.
I will fit one of the gaskets. I'll get a standard one for now, to get it running, then swap it myself later. The EGR valve's done about 45k miles since it was last changed.
Edit: Checked with
MultiECUScan - all looks healthy to me, according to that. All done with ignition ON, but engine not running (it sounds rough, then stalls after a few seconds), so the boost figures are meaningless. Checked a few other things though - a clogged DPF or exhaust was another possible diagnosis, but it looks healthy...
No fault codes
Battery voltage: 11.8V
Baro pressure: 1004 mBar
Boost pressure: 1001 mBar
Desired boost pressure: 1000 mBar
Boost pressure signal: 1617.5 mV
Boost control/solenoid: 74.96%
EGR valve opening: 4.00%
EGR control: OFF
Particle filter status: Normal clogging
Particulate filter clogging: 45.96%
Regeneration progress: 0.000%
Forced regeneration state: Not active
Odometer at last DPF replacement: 136900 km
Distance from last regeneration: 420.8 km
Last 5 regenerations average duration: 542 sec
Average temperature of last 5 regenerations: 618.26 degC
Oil change counter: 5
Oil degradation level: 75%
Odometer at last Oil change: 23396.4 km
Distance to next Oil change: 37500 km
It was due for an oil change early next year, so I'll probably get that done now instead. Other than that I don't see any clues. I don't know why it says the DPF was replaced though - it never has been. Perhaps that's just a quirk, and it shows the current odo reading - it converts to 85k miles, which is its current reading.
I wonder whether the EGR opening reading is genuinely read back from the physical valve itself, or if it's just the ECU's desired position, i.e. is it possible that it would like it to be at 4%, but it's actually stuck at 100%.
