General Induction Kit
rikmargetts
Reading, Berkshire
Hi all,
Not been on in a while due to change of job etc.. but now I am and I wish to find out about these industion Kits that are being sold on eBay, I have seen several on offer ranging in price from £55 up to £85, all claiming increased performance and fuel economy, better throttle response yadda yadda... well is it true and is it worth buying an induction kit for my humble 1.6HSX100 16v? all I want is slightly better performance and maybe improve the economy of it so the wife stops moaning about how much petrol I use.
Thanks:D
well.. the function of an induction kit is to get as much clean cool air as it can into the engine.
but, it needs a clean source. and to be large enough for the vehicle.
tbh you wont get much if any perf gains from it
none that will be noticable.
but you will get a nice sound and the pleasure of knowing it there.. plus it will look good ;)
if you have a full system then there will be a much bet6ter chance of it making a difference, but even then it wont be too noticable
but im still gettin induction. ive heard that BMC are the best for a fiat (i think jug told me that)
the only way to get a real gain is to have forced induction. by that i mean you need to have the induction kit enclosed in a surround, and there needs to be an air intake pipe that is positioned in such a way that when the car is moving at speed air will be forced into the intake pipe, increasing air pressure, which in turn makes induction easier, which increases the efficiency of the engine, giving more power. in addition to increased air pressure, this type of setup will isolate the air going into the engine from the hot air in the engine bay, further increasing the gains.
if you stick a conventional K&N style induction kit on your car in place of the airbox, you will possibly suffer a performance loss due to the hot air taken in from the engine bay. although this is not going to be noticable, and you will get a better induction roar noise. this is what i have on my car and i cant tell the difference performance wise.
So if I understand Jugs correctly I would need to keep the air going into the engine via the induction kits clean and cold and not second hand air from the engine bay? I could do this by some how directing the clean air flow to the filter using the existing parts in the engine that directs the air to the existing air filter... would this be possible or would it negate the effect of having the induction kit in the first place? the way I am thinking is that the air would be fresh clean cold air from the outside under a certain amount of pressure from the forward velocity of driving. would this work? or am I being foolish like my wife thinks.
your theory is correct, and it is what i've done (kept original air intake to supply induction kit with cold air), but the problem in practice is that the stock parts used to direct cold air to the airbox (or induciton kit if you fit one) do not do the job very well. with the air box in place the only place air can be taken in is from behind the grill on the bonnet, since this is where the stock intake is. however once the airbox is replaced by an induction kit the chance of any air getting blasted down the stock pipe is very small because the stock intake holes are very small, and not positioned well enough to hit any real amount of incoming air (stuck behind the 2 tiny holes in the grill is not a great place to be if you want to catch as much air as possible). this means the actual amount of air getting to the filter through the stock pipe will be very small. to prove this i stuck some ribbon in the pipe, and then drove 100mph for at least 2 miles. when i pulled over the ribbon hadn't even been blown out of the pipe. if a sufficient amount of airflow was occuring the ribbon would have been blasted out.
so whats a better option? well tbh who cares, it makes bugger all difference anyway. but if i had an enclosed induction kit (such as when i stuck a peanut jar over mine) then i would be more interested in the possiblity of increasing air pressure. i tried to fit a standard 70mm cold air feed pipe in a position that would allow maximum airflow to the filter. to do this i positioned the opening in the front bumper where plenty of air would hit it directly, and i also tried to minimise the number of bends in the pipe, and how sharp the bends were. i then tried my ribbon test on this pipe and found it was blown out of the pipe every time, proving that a lot more air was going thorough this pipe. but even if i connected this pipe to the peanut jar (increasing air pressure in theory) i couldnt tell the differnece performance wise. i then took the pipe off (& peanut jar) and went back to the stock setup, because tbh it sounds better, and looks better.
So the best thing might be to get larger air feeder pipes and try to minimise any curve in it to give the air as straight as possible flow to the induction kit, or to jury rig some kind of other air intakes from below the grille parhaps in the area by the fog lights or around there, but I dont want to end up with a.) my car looking like its been chav'd up or b.) the front end being full of holes with pipes attached and when you lift the bonnet seeing lots of gaffer tape. LOL... I think I will get an induction kits for the sound alone, and then see what I can do with the forced air idea and see if I can figure out something.
just remember the lower your insuction pipe (initally where the air enters it) the more likely the car is to suck up the dirt and water when it rains ;)
happened to a local bloke with a Cossy :S
question for jug:
jug you have been replying to my thread on inductiion kit swap and there was the problem with the compatibility of the plastic scoop intake behind the grill over the radiator, from looking in the haynes manual the same part on the 1.6 looks compatible to that of mine (1.2 80 sx 16v) so would i be right in thinking it would work on mine?
the bit that sticks out looks like the radiator filler cap. i think on models without an expansion tank there is a filler cap placed there.
according to this pic the 1.6 does have the same hole for the filler cap.
Jug I dont think he means that bit. Think he means the lump of plastic with 3 lines on it, behind the filler cap on the other side of the scoop (y)
lol your spot on with that one jug :D I think it may be an induction muffler. As mine is on the bottom in a similar place to where the 1.2s filler cap is and as mine doesnt have a recess for a filler cap theyve put it on the bottom. And span it to the back of the 1.2s becasue the filler cap is in the way (y)
