General indicator prob..earth?
anton cook
well sorted the com 2000..and now have fully working lights that stay on when needed n go off when needed lol...NEXT!!
all indicators work whem locking car n opening part from drivers side front...ive done the magic trick of removing bumper n h light unit and re soldierd the bit that burns out (bout 3 months ago) all was fine........but now it seems like theres an earth prob with this side front ind...as it doesnt work full stop...taken unit off again an all is fine with bulb and holder and unit....so where do i start looking for an earth fault just for the front right ind???...does any have wiring diag for this.,..as ever cheers in advance....getting there lol..
ant
Have you checked for a voltage in the bulb holder/input wire?
I would test to see if it is the earth by running a wire to the negative battery pole and touching the other end to the bulb's outer in the bulb holder. If it works then just earth out the wire to the body.
