Ok i seem to have a really annoying problem with my UTs idle behaviour. No matter how many times i re-adjust the idle speed back down to 1000rpm this problem keeps coming back again.
Basicly it idles too high like 2000rpm or if i lower the idle speed back down then i sometimes get a problem with the revs going too low like 700rpm which makes the car cut out. Therefore to avoid the car cutting out i've left it with a higher idle speed as it cuts out when i brake or come to a stop if the idles too low unless i manage to get my foot on the accelerator which is tricky lol.
I've changed the coolant sensor before and i have also replaced the supplementary air valve which made no difference. Could my AFM be fooked??? As this is the only thing i can think of now? Also i can hear a slight hiss from somewhere in the engine bay but havent found out where exactly just yet? Could it be a air leak causing this problem somewhere? I've looked at obvious things such as throttle cable getting stuck etc which is fine. Also the Dump valve isnt as loud as it should be either. Any ideas???
F R O $ T Y
