Technical identifying a camshaft
Wrexham
i need help identifying this camshaft and some technical info i can "borrow", im not sure what jamie said it was when i got the cinq :eek:
it a colombo & bariani , looks like this and has FF.103.280S stamped on it
and it also got some writing and numbers on the box - in italian(i think)
thanks
Codice FF.103.280S
Marca Fiat
Modello FIAT FIRE 1108 - 1242 8V
Tipo mono
Utilizzo Stradale Massimo
Alzata ASP 10.3
Alzata SCA 10.3
Fase di distribuzione 24°-76° / 62°-26°
Alzate PMS ASP/SCA 1.8 / 1.8
Gioco 40 / 50
Codici abbinati
CAMSHAFT DATA FOR FAST ROAD CAMS FIAT FIRE ENGINE 1.1 – 1.2 8V
Cam lift
Inlet cam lift: 10.3 mm - Exhaust 10.3 mm
Duration inlet/exhaust - lobe centre angle
280°/ 268° - 112°
Duration
24° - 76°/ 62° - 26°
Inlet valve lift Top Dead Centre (TDC)
1.8
Valve clearance inlet / exhaust (1/100 mm)
40 / 50
Get it slapped in lad.
custard boy said:
gaz are you finally saving up for that sex change op :p
possibly :chin: , might be able to influence the mot if i was female :p
minijohn said:
Gaz - how much for this ?? Please e-mail me at [email protected]
John
have replied to your pm
allanhelen said:
You never fitted it that's tradgic :cry:
don't let it go too cheap its worth over £200 and they are in very short supply at the minute
i wouldnt of been able to fit it, so would have had to pay someone to do it which isnt on the list of prorities at the mo :(
the 1242 is fast enough for me :D
paulbfd said:
£215 from Gazella Racing in Wakefield.
Punto 75 does the same job.
No it doesnt the 280 is a a far wilder cam than the 75. Yes you can have issues with emissions, as the engine is needing a higher stoichimetric value than the cat wants to see, so there is a clash of interests, run it too lean it wont run happy, run it rich enough the cat doesnt like it and neither does the mot tester. To get the best out of a 280 cam you need to invest in some head work as well, then its fantastic.
