ICE
ICE
J
Jag
Am about to put some ICE that is an amp and 6x9. Do you think it is a good idea to also change my front door speakers???Do you think I should add the sub am in two minds???
Jag
The component kit I was considering was infinity 5010cs, so how much better will it be if replace my original door speakers with these??Just wondering Have alot of people changed there door speakers in their cars??
Jag
start with component speakers up front, then a sub in the rear, and either coaxials or components in the stock positions (13cm)
thats'll sound MUCH better than stock speakers in the front and 6x9's in the rear. It does however mean you'd need 2 amps, or a single 6chan amp.
if its just a wee cheap install u want then new fronts, and a pair of 6x9s in the rear is what you want.
but whatever you do, you should always always always replace the stock front speakers.
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Owner of the Bravo 1.8
http://www.bravo-guide.co.uk/members/59ianalexandria.htm
FAO Buzz
Cheers for the advice, sorry to sound like such a novice but when you say the stock front speakers, do you mean the door speakers???Am i right or wrong??
Jag
Re: FAO Buzz
spot on mate. your standard fiat door speakers are pretty weak. stock, OE (original equipment) all names for standard items that can be improved
i should have been clearer on that bit...
S
7
239
Shaun Cook
S
T
1
188
B
E
7
205
S
