ICE
ICE
J
Jag
Dont know all that much about ICE, but wanted to buy an amp. I have already infinity 6x9 and component kit and was going to buy a sub eventually, so the amp i would need would be a 4 channel???
Where is the best place to shop for infinity amps??
Cheers for all the help
Jag
If you want to power the 6x9's, components and sub you may be better getting a 6 channel rather than 4.
As for places on cheap infinity's - pass
Sorry for hijacking alittle but if you wanted to amp the front components and the rear speakers aswell as a Sub/Bass Box how many amps do you need or will a 6 ch AMP be ok?
They do reference (lowest), kappa and perfect (best), as far i a know...
Daz
For every speaker you need a channel.
So for a pair of componants you need 2 channels.
For a pair of 69's you need 2 channels.
For a sub you will still need 2 channels but wired together (called bridged).
Basicaly this is were the power of both channels are combined and are wired as one, ie the + of channel one will be connected to the - of channel two.
(Make sure the amp you get is bridgeable).
So for what you have at the mo 4 channels would be fine. To add a sub you will either need a seperate amp or a 6 channel amp for the lot!
S
7
239
Shaun Cook
S
T
1
188
B
E
7
205
S
