Ice questons
Ice questons
J
JonD
Hi Folks.
Upgrading my amp and front speakers. Prob getting infinity kappas for the front.
Just wondering how easy it is to replace the tweeters, or is it better to mount elsewhere?
as long as the new tweeters have cross-overs on the you will be fine, just take of the OE fiat connector and wire to your new tweets. I have infinity reference tweets in my dash.
You will however need to make a bracket for the tweeters to sit on. easy enough to wok out sizes etc once you have the speaker grille off.
Dan
now sporting my badger badger badger t-shirt ;)
Thanks for that.
Another question what size speakers will fit in the front?
Not quite sure wtihout taking the door cards off.
Treading into tom territory now. ;)
The fiat ones are 5x7" and you can fit 13 cm ones with adapters.
me and smee fitted 16cm jbl gto co-ax's in mine but I wouldnt recommend it to you ;)
Tom will be able to help you more :)
Dan
Looks like will have to goto 4x6 speakers. the 5x7 wont fit what a bitch.
They Should Do ive Got 5x7's In My Front Tight Fit Admited But They Went In With Ease!
They are inifity kappas. There is a big plastic housing which doesnt help. They are way too big. I can get 4x6 i guess. Should be able to sell at get my money back.
Maybe a daft question. Did you try fitting the speakers from the inside of the door? Just asking because you said the plastic housing was the problem.
S
7
240
Shaun Cook
S
T
1
188
B
E
7
205
S
