Right, removed the tank from the Donor 750L, had half a tank of fuel lets, so me thinks, ohhhhhhh, lets syphon it into the Sisley.
So I stick the pipe into the filler neck, then clonk. The flipping jubiliee clip from the small fuel feed pipe has fallen into the filler neck on the Sisley :bang:
Why I didn't remove it before I don't know.
So it's now sitting on the anti syphone mesh in the filler neck. Question is should I remove it? Is it going to rust away and cause problems, or will it just sit there until the end of the earth
Also, if I try and remove it, will dropping a manget on a string in get it out, and do magnets spark causing explosions
:bang:
FFS.
Jon.
P.s, I've filled up with it there once and it caused no problems then.
FFS.
Jon.
