Don't do it, I've got one...unless you need the driving position then get the 159. Points already raised by others are all valid. The Croma is blighted by the Vectra chassis whereas the 159 is not. The extra weight of the 2.4 means the suspension, tyres and brakes wear quicker, the extra torque means the (Fiat/Alfa) driveshaft inner joints wear quicker (mine are now juddering after 45K), the extra cylinder means the steering lock is poor and makes cambelt changes v difficult (eLearn says take the engine out - I hope I don't have to next year when its due).
Fuel economy is also disappointing, the rear suspension is inadequate for towing a heavy caravan and the gear ratios are less than ideal for towing.
If this sounds like I'm disillusioned with the Croma then I've got the message across. I was hoping for something more reliable than my last car (a VW Sharan VR6) but it's not looking promising.
Trouble is, there's nothing else on the market that has the combination of enough headroom for me, a high seating position for my wife and a diesel engine with automatic gearbox capable of towing 1400KG. So - I'm stuck with the Croma and will have to fix whatever breaks until such time as a viable alternative exists and is affordable
Before all the 'Fiat is the best car maker in the world and anyone who thinks otherwise is a Fascist lunatic who must be burnt at the stake' people get on my case (or T109232864 or whoever he is tells me to get another car if I'm not happy - yeah, thanks for the advice and support mate);
I've had 22 years of driving experience and owned in the region of 50 cars of various makes. I'm an aircraft engineer (mechanical) by trade and know how to fix things when they go wrong. I like Fiats. I like the concept of the Croma.
I just feel somewhat let down by the build quality and the cynical cost-cutting that allows someone in design to use the same driveshaft joint as the Alfa 147 when the Croma weighs so much more and has 400NM of torque. Or allow the continued use of a water pump which fails regularly and takes the cambelt out. Or fit suspension springs that are blatantly sub-standard and catastrophically rip the front tyre when they break. Or allow cars to leave the factory with the rear wheels pointing in different directions.
And we accept these things, and whatever else randomly fails, for whatever reason (in my case because I have no alternative) but I'd rather let other people know what they're getting into before they spend their money.
Rant over
