Hi all.
I bought a 2006 1.3 multijet turbo punto grande at the start of the year with a broken selespeed actuator master cylinder. I searched around for a replacement for a while and ended up finding a complete gearbox 6 months later. I live in Australia and there isn't much of these cars around.
I only replaced the part. When replacing the oil as it had all came out as the master cylinder was cracked I couldn't find the correct oil anywhere local so I read on an alfa forum that you can substitute it with dex 3 oil. It's been running fine with that for the last 2 months I have been driving it around. However I would like to replace it to the correct oil as I have found a supplier.
I've had a search on the forums and can't find the correct procedure for replacing all the oil. Can anybody point me in the correct direction.
I have multiecuscan so bleeding the system is no problem.
Any help or guidance is much appreciated.
Jakob
Jakob
