biscotti Member Joined Dec 30, 2012 Messages 214 Points 64 Location south wales Feb 16, 2013 #1 Hi,how do you remove the rear fiat badge?I have a new one I want to put on.also has all barchetta's got a boot light?there is a little rubber button next to the boot lock but cannot find a light in there?
bollie69 I own this title Joined Jul 30, 2009 Messages 671 Points 113 Feb 16, 2013 #2 The button is for the buzzer when you try to open the hood compartment and the trunk is open. You can't do both. Just pull the badge off, it's put on with adhesive tape and 2 smalls pins that pop out. The front logo its bolted on from the inside + adhesive tape
OP OP biscotti Member Joined Dec 30, 2012 Messages 214 Points 64 Location south wales Feb 16, 2013 #3 Ah thank you,OK I will carefully pull the badge off,thanks again
KC3 Patron member Parked in the garage Joined May 23, 2007 Messages 2,125 Points 483 Location Nicosia Feb 17, 2013 #4 biscotti said: also has all barchetta's got a boot light?there is a little rubber button next to the boot lock but cannot find a light in there? Click to expand... I added two small lights into the boot and wired them to work with the the switch. There's lots of pictures and a guide in my KC3 thread. https://www.fiatforum.com/barchetta...661837.html?highlight=boot+lights#post1661837 and also another easy guide here. https://www.fiatforum.com/barchetta-guides/138621-barchetta-boot-light.html It a nice modification to have.
