Mega Panda White Camaleon
- Joined
- Nov 22, 2008
- Messages
- 9
- Points
- 4
Hello friends, we will paint the wheels of our fiats? well let go,
1st in the case of damaged wheels (body filler, sanding 180 (to good use alloys 400 and 600 sandpaper) and Scott BRITE thin, primary, and synthetic metallic gray, so we need a professional finish silver metallic base coat, and LAKAOS (Verne) ,
For wheels on iron do not need filler, we will work ..
we first sanding the rims, they have mounted in the tires we have to isolate adhesive tape, we will take all the imperfections of the rims in the case of small holes and scratches, apply filler and sanding, clean and well after the rims hope apply primary drying , Next step is sanding the primary, with 600 and scott sandpaper, and wipe the rim, isolating the rim of the tires if necessary, and apply the silver metallic and expect to implement the Vernis dry, the gray stain can therefore apply a hand and look dry, then apply another, until all covered, then expect dry, and give a mild smoke to get the ink stained, and is only applied Vernis and expect dry,
Good luck
Good luck
