Technical How To Change Gearbox Oil In Punto Mk2 - 1.2
jimmyx1000
Hi
when i first start the car in the morning it seems a bit stiff for about 5 mins,
ithink adding oil to the gearbox should help , how can i do this
can somebody tell me where the gearbox filling hole is on the punto mk2
year 52
thankyou
No need to add oil unless level is low. Depending on mileage it may be worth changing the gearbox (transaxle really as its combined with the differential/transmission) oil ensuring you use the current grade. Easy DIY if you have the correct tools. Do a search as there are other posts on this topic...
Need a 12mm and 8mm Hex Or Sump Plugs IIRC
Case of - Get a Bowl under the gearbox
the Drain Plug is at the back of the Gearbox - facing the The Bulkhead on the passenger side
It may be covered in lots of road grime - so you might have to clean it first before removing it
Then unscrew the plug - drain fluid - Clean the Bung up - as it might have some small fine Metal dust - which it should catch as its magnetic
Once its drained down - replace bung
Undo the Filler Bung - its smack Back in the Middle of the gearbox itself - on the passenger side - its about half way up
Undo the 12mm Hex - And Fill the box back up with 75/80w Gearbox Oil
I think it was 75/80
And keep filling till you start to overflow out the filling hole
When its overflowing - you're full
replace bung
check daily for signs of leaks - No Leaks - Be happy with your work :)
Ziggy
Ziggy,
Appreciate all the info on this forum. Just changed the clutch on my 04 Punto. Now considering whether to change the gearbox oil, car has done 150000 miles. Have found level/filler plug and drain plug but what is this cap for on the top of the gearbox? Can I fill the gearbox from here as it would be much more convenient than using the level plug to fill?
Unbelievable question in the year 2024 on a technical/automotive forum.
This is a vent. Don't touch it. If you try to remove it by pulling you will break it (99% chance) and one of the clips will fall into the gears.
Hello everyone .
I am a newbie, I have a 1.2L 16V ELX SpeedGear A (CVT transmission).
When I press the brake the transmission light comes on, And now the light just flashes and it makes the reverse gear tone.
I realise it’s a cluster grounding issue that shares the same circuit which causes this (so I beleive).
In any case it has caused an issue with my gearbox causing the shift from park to reverse to be jerky , almost like a shock.
I THINK fixing the grounding in the rear light cluster will fix the issue , but not sure.
Relevant to this thread, I don’t want to go under the car and open the sump/filler plug.
So can I feed an extraction pipe into the gearbox dipstick, extract the oil and also fill it through there? It would be a lot easier for me.
Is it okay to do that?
