General How to Access Panda 100hp Workshop Manual
Baggey
Kernow
How to Access Panda 100hp Workshop Manual!? I ve downloaded the 6/7 Parts and have an .mrt file!? Now What?
Hello,
I assume you've downloaded it from the downloads section.
First, it will work on a Windows computer only.
You should have all 7 rar files. You have to unpack them by double clicking, starting with the one with the part01 in the name. It will unpack the whole archive (7 files). It might work only with a third party software, like 7zip/ WinRar etc, not with the built-in Windows thing. This should create a single iso file. It's an image of the original CD.
Now you have to mount the iso file to a virtual CD drive. I'm using UltraISO to do it.
Then, once mounted to the virtual drive, you have to install the eLearn software on your system. And if everything works well (it should!), you will be able to use the program. However it will require to mount the iso image into the virtual drive everytime you want to launch the program.
  • Like
Reactions: ben
Hello,
THANKYOU!
