hornless
hornless
Llanymynech
my horn stopped working yesterday and i dont know why ;)
Any ideas guys
cheers
sammi
I have a bling* bling* shiny blue thing
check the fuse. i aint got a bravo so dont know much bout the wiring for it, so if it aint the fuse im un-helpful lol
Seicento Sporting, Modified Front Bumper, Saxo Custom Spoiler, Abarth Side Skirts, Bad Boy Bonnet, Afterburner Rear Lenses, 4" Powerflow Exhaust System, Abarth 14" Alloys.
IN THE PIPELINE:
-40mm Drop or Coilovers, New Front Bumper, Rear Splitter, New Mirrors (Not the cup ones[xx(], something different)
Check out my site http://badboygaz.mysite.freeserve.com​
FIATForum stickers available PM me for details or see: https://www.fiatforum.com/forum/topic.asp?TOPIC_ID=10000
Sammi, my electronics knowledge suggests:
Could be a damaged horn, considering it went off when using it, it sounds like this - something internal blew etc.
Could be a fuse as Gaz has said, although a blown fuse usually suggests something is damaged also.
Could be a connector to it has fallen off (there will probably be two wires to it, just check that both are on properly and have a good connection.
Paul
Uno 1.0ie Start. Standard.
My Punto's original horn died when I was using it, a very short beep, more like 'b' and it was no more. Halfords or other similar places sell em, and you can find a few on ebay as well. Not to hard to replace, but I recomend a locking nut when you put the new one on. After my original one had blown, I tried to use its replacement only to press and get no sound, because it had fallen off...
Punto Mk2 ELX 8v in Teseo Blue with the electric Sunroof and CD changer, doing 50mpg whilst passing down country lanes
same as me sammi, horn died but i smacked mine hard (fighting with g/f) and doesnt work no more no idea how to check though just leave it till mot needs doing :/
Well, mine just died spontaneously the other day.
Checked everything, all was well, but no horn. Bought a replacement horn, went to fit, checked it was still not working, and the bugger was. [:(!]
Fitted the replacement anyway because it sounds better!
I reckon water and age have things to do with why they die!
Tom (AofB)
95 Cinq Sporting - Rattly GrpN Catback Exhaust, <font color="black">Buckets</font id="black"> and 3pt Harnesses,Sexy VW styleé dials (that look great, but dont work!! :)D)), 10" Sub and 6x9's, ETech Wing. Lots of Dirt!
1242cc Engine in car, not wired up, need new inlet manifold!!, boot delock soon, K+N still in garage!
My old horn did the same, worked then didn't, it was just the connections, although I have a spare Uno for parts and swapped them, same horn, same model number, twice as loud! lol, other one had perfect contacts so was a lot better. I needed it to work for its MOT, which is coming up in a few weeks [:0][:0]
I pressed mine today when a Saxo driver pulled out of his drive backwards towards me coming down the road without looking, if i hadn't have honked i would have had my first crash - a guy reversing into me! lol. Idiot thought it was ok to reverse without turning around/checking mirrors....
PS. The fact he was a saxo driver is neither here nor there to me, although it might matter to you lot lol
finally got around to looking at my horn - well i couldnt get the bonnet up so i took it to the local garage in the village - the catch is well knackered so i need a new one - also they had a look at the horn too - both the horns are knackered - the contacts have coroded off both horns, so i must only have been using one horn - £4.20 for the catch on the slam panel and £20 odd quid each for the horns!
they are much better than the standard noddy horn on my sei
i recommend the halfords horns, even i managed to wire them in:D
my only problem is that it turns the code light on when i use themB)
IN THE PIPELINE:
I believe that the only law is that you can't have more than two pitches to the sound...?
