Hi my 2013 500 1.2 fan is running all the time and aircon is not working? I have replaced the radiator resistor and no joy, what else shoud i be looking at ?
hello and welcome ,to try to understand your problems better!- firstly did they both occur at the same time? or did one issue happen before the other!.
Turn off the ac, turn off the fan inside the car, when cold at start up does the fan run, or only when hot?
Check the water level in the radiator!
If the fan runs at cold start up, first check the fan relay, is it stuck on?
The ac, when was it last re gassed?
