Grande Punto High beam issue
shella
Essex
Hi all,
Newbie to forum. Wondered if anyone could help me with my punto grande.
Got to have re-mot by next week.
So have problem with high beam.
Side lights work and I can flash my high beam.
When I put on my headlights and flash there is no high beam, and also pull back on stalk to activate the high beam i have no high beam.
I have managed to sort all other small issues as per mot, but am left with this problem. Have checked fuses, but without a manual. Online search's brought up some to check, can't find relay for high beam if there is one.
Thank you in advance if you maybe able to help. 😀
With the headlights OFF if you flash the high beam they work, yes ? And the blue tell tale is on the dash, if yes to all then the supply, fuse, relay and wiring are all OK.
That leaves the stalk itself and the BCM, I think, though I'm from the 500 section
