hii im a newbie az u may hav guesssed lol!! im am on the verge of purchasing a mk1 uno turbo!! the 1st mod i want 2 do is increase the boost to 1 bar...which i understand standard internals will cope with (if the engine is sound!!). wat little tweaks will need 2 be done?? i kno a bleed valve will need 2 be installed 2 reach the pressure(thinking solenoid operated)...and i will also install an adjustable fuel pressure regulator az i thought it would be wise...but will i need 2 bypass the overboost switch?? or jus simply disconnect it?? and also any other modz needed?? plzzz help!!
many thanks
adam
many thanks
adam
