A
Adam
Hi Adam (joske)
can you help on my air con problem?..used your diagnostic technique from the fiat forum as mines not blowing cold and compressor doesn't appear to be kicking in..outer pulley spins with belt but inner section not moving when air con switch engaged,... lcd display showed 'code C :.' then 'error 00'
is it ok?..or is the compressor dead?
cheers!
Adam
cheers!
Adam
