Andrew Harper
- Joined
- Jan 9, 2010
- Messages
- 6
- Points
- 1
Hi guys (and girls),
First Post, hope you can all help me!
Recently changed the timing belt on our '98 Brava and for about two months all was well.
When I last left the car and started it the next morning, there was a collection of sounds which caused me great concern!
Guessing it might be the Timing Belt (again) I removed the timing belt cover and have found that the belt has gone slack and is no longer taught between the gearing.
My question is, what is the correct way to tension the Timing belt Tensioner pulley?
I have the kit which includes the tensioner tool (the one like a bar that pivots on the side if the block and pushes against the pulley to take up the slack)
The replacment pulley that I was sold does not have the same setup marks on it that were on the original (which broke when the timing belt failed last time).
Sorry I don't have any pictures.
The service guide refers to two seperate settings, I am wondering if the pulley "floats" or is supposed to be fixed.
One final note, when fitting the new belt it was a very tight fittment.
Thanks, Andrew
Thanks, Andrew
