Styling Help on alloys
coldfirejones
Hinckley
I bought some 13" alloys for my fiat uno and i took them to quick-fit to get them fitted but they said they cant put them on as i need bigger spacers? any idea's where i can get some from? because im lost... :mad:
What 13" alloys are they? ie what car have they come off?
Have a look on the back of the alloy and post back the offset, should be et**.
Then we can work out if you need spacers (y)
Also, why didnt you fit them yourself? You would save money, have the satisfaction of doing it yourself, and most importantly not let any quikfit cowboys near your car!
8003499072, (thats that number on ebay) they dont fit at all, the plastic ring doesnt fit on the hub of the car, are these just utterly wrong?
Have they got any markings on the back of the wheel?
Judging by the ebay auction then they should fit but he might have been lying.
raised letterings, or engraving, stampings, anything with letters and/or numerals, would help a great deal
little odd how the ad says for a cinq - with spacers, or an uno........
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8003499072 are these the wheels?
if so, they WILL fit but what you will idealy need is a set of proper sized spigot rings. thats why they dont fit the hub. If they came with them (little coloured ring that goes in the centre where the wheels will go onto the hub) then they are probably wrong, specialy if they dont fit :p
you will need to measure the diameter of the little recess where the spigot rings go and then tell
http://cgi.ebay.co.uk/WHEEL-SPIGOT-...005095851QQcategoryZ14771QQrdZ1QQcmdZViewItem
this bloke that you need the spitgots of that size to a fiat size :)
he will know the rest.
As for spacers. those wheels are a 38offset which should be fine although it would make they look a little better with some 5mm spacers (can get them from halfords) as it would make the wheels stick out a bit further. they will probably look lost in the arches with that width and offset :(
