Help needed, electrical weirdness going on
J
jayfish
got home tonight and pulled up, turned stuff in the car off, handbrake, neutral etc.. turned off the ignition and the injector light, battery light, brake light and ABS lights all lit up?
I checked i hadn't put it round to park, then put it to park...no difference.
i restarted the engine and it was all normal, abs and battery lights went straight out, injector after a second and brakes stayed on because of the handbrake.
turned the engine off and same story as before, opened the door and the door light came on but flashing instead of steady ?!?
I need ideas!
Oh and then i went to lock it and the remote locking just gave a single folorn beep, tried again and got the same, tried a third time and nothing, zip, nada.
had to manually lock it which did engage the central locking
I have no alarm!
Try battery off mate. Ye olde ancient cure-all for the Bravo. ;)
Shabash!
Now partying with Yul Brynner
http://www.billhicks.com/
http://www.geocities.com/ozrictentacles_web/
I guess I'll have to, wanted to avoid the 500 miles of expensive relearning though :(
problem solved :)
after a little head scratching and removing my boot build I worked through my wiring plan and found a single loose strand of wire connecting live to acc on one of my amps, which was giving live to evrything upstream on the acc wire, doh!
F
7K
F1-ANG
F
E
1K
E
C
2
836
K
A
577
anthony jenkinson
A
