General Help ! my engene is stoping working
mishadbIL
Israel.
Hi all
i have 1.0IE uno,
the car is grate, but i have this problem,
the engene is sudelny stoping to work, it can hapen while i drive (about 100-80 Kmh), and it hapens while i standind too......
this happen about every 5 km drive......
i already ask a few peuple, but nobody know what is it
i put a new fuel pump and fuel filter but it isn't help....
HELP ME PLS !!!!!!!
i cant drive faster..... we have here speed cameras.... :-(
the simptom is very simple, while i drive the car is simply stop work
( like i have run out of fuel).....
most of the times it happen after i drive 80-100 and stop in the red light....
What's the car's temperature when it stops?
Does it stop when idling when hot / cold etc.?
Morten.
abarth wheels & steering. ia lowered. pg audio. refurnish.
projects: air intake. (used) seats. exhaust-repair. legal tint.
most times it hapen when it hot, but it hapen once at cold engene(in the morning, afret all night whitout work)...
Hi all
i have found the problem !!!!!!
i replase the vacum distributer and modul unit, and did a very good clean to the injector.....
this sove all the problems :)
mishadbIL, did you follow my advice then and it made it work? I think the vacuum advance pretty much causes this problem?
Uno 1.0ie Start. Standard.
I am a schizophrenic currently so please bear with me whilst I try to get rid of the 40+ personality.
yes, but it's not only the vacuum , i think thet the electronik modul was not good too
I've been running with a blown vacuum unit for thousands kms and the engine seemed to be working properly...these symptoms are due to a failed module!!
Passion has neither brands nor models!
La passione non ha nè marche nè modelli!
(Quite happy dark met. blue Panda driver!)
Enzo; all I am saying is that I got often stalling from my car, when this module was replaced, it ran perfectly from then on!
Yes I had the same prob with the module. Had it replaced and runs like a dream now! It seems that this is a common problem.
Hi all
hi mishadbIL,
today i got the same problems with my uno 1.0 as you have discribed.
the module unit and vacum distributer you are talking about - what is it exactly? i cant emagine what it is...
i do not know the english meanings exactly... :)
would you be so kind to discribe what exactly you mean...
thanks,
bolte
Find the distibutor on your engine (if it has one:I)...then on the front side you'll see a thingy with a rubber hose connected on going to the carburettor/butterfly body base, this part is the vacuum advance unit!Then on the "rear" side of the distributor you can see a "flapped" piece bolted on, this is the electronic module which provides to "create" the high tension in the coil!
Only a dream inside my head...take a look at the avatar! (Oh...no!!)
Does this help? It is a picture of the Uno 999 engine WITHOUT the airbox so it does look different:
47b4db29b3127ccebe788533ed550000001610
Bolte: I guess the wise decision would be to take your car to an auto-electrician who would have the appropriate equipment to identify the true nature of your problem.
