Jtebs
Been trying to figure this out for over a month
I have a 2012 fiat 500 Pop 5 speed manual. It hit 70k miles this past summer (currently at 73k). It has been in my family since new purchased in January of 2013 (leftover from 2012). It was my mom's car for a couple years, then I learned to drive in it and it was my first car, and I still have it. I've been driving it since 2015. Until now it has been dead reliable. Never given me an issue before and I absolutely love the car.
So in late October I was on the freeway on my way to work and my check engine light came on, along with my ESC light and ABS light.
I keep a simple scan tool under the passenger seat so I read the engine code when I got to work and it was an evap code for gas cap. I cleared it and it didn't ever come back.
The ABS and ESC lights remain on, and every time I start the car I also get a warning that hill start is unavailable.
I have a more advanced scan tool in my garage that can read ABS codes and it reads no faults. I took it to my local Chrysler/Dodge/Jeep dealer and their scan tool also says no faults with the ABS and ESC systems. We t to a local mom and pop mechanic shop, same result on their scan tool as well
So I took to the forums to find solutions, here is what I've done so far in no particular order:
Replaced all 4 wheel speed/abs sensors
New pads and rotors
Checked for wiring issues in the boot to the hatch
Replaced battery
Replaced Earth Strap
Cleaned and sanded the supposedly problematic grounding points on this year of the 500
Replaced brake light switch
Flushed and replaced brake fluid
Reseated wiring harness for the ABS module
Rotated tires
Double checked pressure is correct
inspected for treadwear
Checked wheel bearing condition
Got an alignment
None of this has fixed the issue and with no codes pulling on any scan tool I am stabbing in the dark and I am completely out of ideas.
I got new tires too (General Altimax) but that was because they were wearing out, not an attempt to fix this issue.
It runs and drives perfectly fine, and I don't need hill assist and typically drive with it off anyway. But I really want the lights to go away and I want the piece of mind of kno6tgese safety systems work.
Also, my state inspection is up at the end of this month, and to pass I can't have any warning lights. So if I don't figure this out soon I won't have a car I can legally drive to work anymore.
I love my fiat, please help me save her!
New pads and rotors
Replaced battery
Rotated tires
Got an alignment
- Model
- 500 Pop (5-speed)
- Year
- 2012
- Mileage
- 73000
