Stilo Help me I'm new! Please!!
Joshmaher89
Please help me! I can't get into my fiat stilo 54 plate 1.6the key fob has never worked, but now the keys don't manually, I'm sure the batt is fine because it is new, the boot lock won't Evan turn! Any suggestions before I torch it??? Never buying one again as iv had non stop problems! But need to get some things out of the car lol
if you dislike it that much smash the window in, thatll solve your problem.
alternatively, get some silicone 3-1 lubricant, spray it into ALL your locks. walk away 10 mins, come back and spray into the locks AGAIN. push your key in but dont turn to unlock, turn and hold it-all your windows should open at least, and hopefully the doors will unlock.. Do this on a dry day.(y)
The key turns in the driver side but nothing happens, the little light on the door still flashes, the boot keyhole doesn't turn at all :s... And there is no passenger keyhole,
The boot keyholes tend to get seized up because people rarely use the key to open them, we have that issue with both of our Stilos, WD40 fixed it.
Has the key ever worked to unlock the door manually?
Try all the above suggestions. Its not worth getting rid of it because of what could be a simple fix. I know you have had problems with, i have, but stick with it. They are good cars and will serve you well.
Phil
