- Joined
- May 12, 2008
- Messages
- 5
- Points
- 3
Jumped in the Multipla this morning and noticed a horrible diesel-like smell. After much rummaging around underneath the car and under the rear seats I found the cause: a can of diesel treatment that had been crushed under the driver's seat sliding mechanism.
But, whilst searching for the source of the mysterious diesel odour I noticed a small rubber pipe on the front underside of the engine that has been completely severed!
The pipe is a soft, silicon type rubber in bright red and connects from a small cannister object that is mounted on the front lower-edge of the engine and points down at about a 45 degree angle (roughly behind the number plate). The pipe is about 18" long and runs up below the air cleaner to a small square device with some electrical connections (sorry, I'd take a photo but my wife has gone out for the day in the car.)
I think I have identified the tube in the FIAT ePer catalogue, arrowed and indicated in red in the following image:
The part SGR. 10252 is listed under the SUPERCHARGING category which I'm guessing is the "turbo" as the JTD 110 is a turbo-diesel model:
I can easily fix the hose but would like to know what part #55188059 is as it is only listed as "ELECTRO-VALVE"? Is this the infamous MAS? Would it also explain why my engine management light is now permanently on but the car still drives fine?
Thanks for any help and guidance.
