I imported_Highlander New member Joined Oct 22, 2007 Messages 14 Points 5 Oct 28, 2007 #1 Hey, Im going to try and debadge my mrk1 punto front and back but have no idea what to do if someone could tell me what i need and what to do ? :lol:
I imported_puntomatt Prominent member Joined Sep 5, 2006 Messages 2,360 Points 523 Oct 28, 2007 #2 The rears badges are just stuck on so take out a kettle and a plastic spatula - if there's any glue left on the bodywork tar remover will get it off The front one is bolted on iirc so it's gonna leave a hole
OP OP I imported_Highlander New member Joined Oct 22, 2007 Messages 14 Points 5 Oct 28, 2007 #3 ok thanx m8 ill post pics when im done
I imported_Mark Established member Joined Aug 27, 2005 Messages 1,645 Points 293 Oct 28, 2007 #4 IIRC on the Mk1 the rear badges were also held in place by positioning holes. Meaning that holes shall be left if the badges are removed on the rear.
M21MFS Patron member Parked in the garage Joined Aug 3, 2004 Messages 10,953 Points 2,391 Location Aberdeenshire Oct 28, 2007 #5 Mark said: IIRC on the Mk1 the rear badges were also held in place by positioning holes. Meaning that holes shall be left if the badges are removed on the rear. Click to expand... I believe your right on this one mark - the wing badges were the only ones held on by gluey stuff, though maybe someone knows differently?
I imported_puntomatt Prominent member Joined Sep 5, 2006 Messages 2,360 Points 523 Oct 29, 2007 #6 What the **** were Fiat thinking when they had that bright idea??
I imported_Mark Established member Joined Aug 27, 2005 Messages 1,645 Points 293 Oct 29, 2007 #7 puntomatt said: What the **** were Fiat thinking when they had that bright idea?? Click to expand... They were probably thinking that they don't want people removing their name from their products But im almost certain the rear mk1 badges are pinned.
OP OP I imported_Highlander New member Joined Oct 22, 2007 Messages 14 Points 5 Oct 29, 2007 #8 lol ok if de-badging mrk1 what will i use to cover the holes ?
P punto55 Patron member Joined Jan 12, 2006 Messages 261 Points 68 Location Glasgow Oct 29, 2007 #9 you will need bodyfiller and put somthing behing the holes so the body filler dosent fall thro.
