OK, this is the second time it fell out. First time it fell out I put it back and it was fine. Now I can't get the tension in the spring to hold it up as it was designed. Can't figure out where the spring end on the right side spring is suppose to sit in order to keep tension in it. Also I don't know if there is suppose to be a spring on the other side. Can someone look or snap a photo of theirs so I can fix it. It's a small problem but annoying, thanks.
Also, does anyone know if the interior footwell and side and buckle belt plastic covers are ABS plastic or some other kind?
