Technical Help a guy out
Freshman
:confused:Hey uno dudes and dudets,im kinda new to uno's and cars in general and need any advice on how i can get my old girl to run like race car..........any tuning tips, top secrets or special parts that i should know about...pleaz guys:confused:
??????? formula 1 engine?
need to be a bit more specific,
first thing id say is sort the suspension
As stated above we need more info. If you are wanting a car that handles well then suspension and a torquee enigine setup is what you need. On the other hand if you want speed then you need to get more bhp out of your engine.
For handling you will want to add stiffer shocks and lowered springs, you might want to consider fitting an anti-roll bar and maybe welding up the rear beam. The engines generally give good torque, but if you are interested you could try fitting a 1600cc FIAT Tipo motor.
For speed you will need a new cam shaft, probably twin carbs.... the list goes on. So tell us what you want to use the car for and we'll be able to give advice.
