hello from belgium
hello from belgium
erwin eeckhaut
aalst
hello from belgium , We do have a fiat 500C 2013 (steering wheel on the left side) where we have a battery drain probably due to ECU bluetooth module... I read that ECU Bluetooth module sits near the rear end speaker ... is this ECU Controller located on the left or right side in the rear of the car ? It takes a long time to remove all the panles , so I need to know what side i need to remove the panels .. can anyone help me ?
I also see that there is a leakage in the water canister or a connection tube for wiper cleaning . Can anyone help me how to find out what need to remove to access this pump ?
Hi and welcome :)
Yes, it's the Blue&Me module that needs to be unplugged, usually left side.
This video shows how:
Then you have options. You can leave it in place, remove it to send off for repair or throw it in the bin, which is what I would do, the software isn't supported any more.
If your dash is flashing you'll probably also need a proxy alignment. MultiECUScan is good for this.
More here:
