Thunderer
The heating in my Uno is average at best. During the freezing period when it was below -10 C, the heater would just enable a little milder temperature, that combined with the body heat of the passengers made driving in it bareable, but no way would you be comfortable driving without a coat on. When I go onto an open road the story is even worse. Even though the engine is much hotter the heater would release air only minutely milder than the outside temerature. I'd have to slow down to 60 to 80 km/h to feel the difference.
When I set the heater on the control panel to blow through the outlets on the panel, there is actually no difference in the tempereature what so ever. I only feel a difference when the air is set to blow through the windshield outlets and a milder temeperature when set to blow at the feet (I hope I am making myself understood here).
Is this normal for an Uno or should I try to repair it myself (not a mechanic though). Is there a simple push the button trick somewhere under the bonet or a duct tape solutio, or should I take it to a mechanic to fix it?
