Technical Headlight problems
cader123
So i am finishing restoring my 79 X, when we where checking the electrical system we make all the lights work except that the headlamps after some working (4 or 5 up and downs) they started working non-stop. But on the coil there was no electricity. we find out that on the red large connector on the fuse block had a problem on the brown cable so we cut the brown cable (entry and exit) and connect them in outside of the connector also we find out that the battery connector had a a false so we connect them in other way. after those modifications we had the problem that none of the lights work at all. we called an electrician who repaired everything except that the headlamps motors didnt work anymore and in the headlight switch the first position ''off'' all the lights work, in the second one '' headlamp motors and courtesy lights'' everything turns off and in the third one '' all on''' happens the same as the first one.
today i noticed that in the I and L fuse there is no current at all.
Whats happening?
