nicely done and lots of pics!!
thankyou kind sir!
anyone know if the cam can be changed without taking the head off??
Yeah, not a problem. Only thing you need to do is to lock up the pulley directly before you try and loosen the nut (very tight and there's a danger of shearing the keyways). Worthwhile replacing the seals and checking the shimming while you're in there.
nicely done, can i suggest adding a couple of things though.
flush the cooling system if it has had oil in it.
also, the head bolts.. before being fitted, they should be oiled. What i do, is dip them in oil and then wipe most of the excess of. Too much oil is bad, but it should have a bit in there.
the sensor near no1, is for the temperature gauge and the blue sensor on the inlet manifold is the ECU's coolant temperature sensor.![]()
It does say I put plain water in, while I checked for leaks etc, then drained and refilled with water/antifreeze
The bolts were soaked in diesel for a few hours before fitting, then any excess wiped off just before fitting, too wet and it can lead to hydraulicing[?], I forgot to mention that, plus, some bolts come pre oiled, ones I have bought in the past have been.
