Hazards
Hazards
imported_Russell
Ok this is wierd my hazard lights dont work? everything else is fine (cept my central lockin which doesnt work everytime but that dont matter) cept my hazards
I put it in a mechanics for something else n asked them to look at it but they couldnt sort it n said to go to an electrician which I aint done yet anyoen know what it could be or had it happened before?
first thought is do ur indicators still work?
if so check the hazard fuse (compartment right hand side of steering wheel)
ther are probably 2 different circuits for the indicators and the hazards as ur indicators only work with the ignition on and hazards work regardless.
if not the fuse possibly the relays buggered, have a look in a haynes manual to check the circuit diagram (or look in the user manual to locate hazard relay), the relay will probably be in the glovebox behind the hatch and simply pulls out (small black cube).
try these first as they are simple to change and can easily be aquired from a local scrappys!
andy
Sporting Cinqy M Reg and yeah the indicators work altho not if I put my hazard switch on and try my indicators
I'll check the fuses later tonight
