General  Handbrake cable Eper help
Hey there
2003 jtd.
Just looked on eper for the left long handbrake cable( drum brake)
I haven't used eper in a while(having a relatively reliable patch) but there's 11 versions listed for the cable so I'm unsure which to get.
9 are greyed out then there's 46556689 51733787 left
I forget which engine code the jtd 115 is M7 by any chance??
Zfa18600002200208 is my vin
Marty.
Yes - M7 is the JTD115. If you put your VIN in the box early-doors on eper (sounds like you did, because you're getting greyed-out part numbers) then that does most of the donkey work for you. Anything greyed-out doesn't apply to your car.
I'd guess that the two part numbers you're left with are for disc brake and drum brake versions. Because of the problems suffered with the disc set up, some Fiat dealers converted disc ones to drum after the fact, so they'd need to show both types of cable to cover themselves. Also, I think 2003 was the year they changed back from discs to drums.
I can have a look on eper using my VIN (2004 roundnose, so there won't be any disc version to worry about) if that helps.
Cheers guys
Yeah had input the VIN
M7 so points me to the first one thanks a million.
I'll prob replace both if them.
Marty.
