Grande Punto Touchscreen Monitor Compatibility
Tym
Established member
Worksop
Right so I have a 1.9 Mjet GPS - I want to keep my steering wheel controls and the use of my blue&me system, how is this possible?
I want to buy a Touchscreen for my dash to replace what I have now and to also hook in a computer system with GPS and GPRS and Wireless.
I'll also be hooking in front and rear view camera's and an internal camera - all with infared.
What inputs/outputs does the headunit need?
Tym
Just replace the B&M components with add ons to the Carputer. Most computers will be Bluetooth compatible and the input port is just USB so should be fairly simple to re rout to the Carputer. Not that you will really need it, i just sold a carputer with 120g HD so it acts as an MP3 player.
There are a number of Front ends that use a stripped down version of XP to minimise any loading times and the use of an M2-ATX PSU can get start up times as low a 3 seconds :eek:
You need to think about where you put the drive for the computer as you will need a direct input.
Also you need to check that the computer is compatible with the Aux in on the motorised touch screen.
If you need any more info please dont hesistate to ask.
Quick question, What do I need to connect my carputer to my OBD2 Socket? I'm assuming USB to [FONT=Arial, Helvetica, sans-serif]16pin OBDII[/FONT] connector?
I want to be able to display live data from the car.
