Hi
I have recently noticed that my Idea makes a running water/glug noise. This is most noticeable when revving from idle when the car is stationary and usually happens when the car has just been started or is getting up to temperature.
I've read elsewhere that this can be indicative of problems with the water pump or an air lock within the cooling system. I've also read it's potentially a sign of imminent head gasket failure.
My Idea runs well, pulls well (for a 1.4!
), idles well and doesn't misfire. The temperature gauge, after the car has warmed up, always sits bang on the centre of the dial and never budges, except in really hot weather (not now then!)
There's no mayonnaise under the oil filler cap or on the dipstick. The coolant hasn't been changed recently and is possibly quite old. I find it's a right pain to see the level for the coolant in the Idea. It does look a bit dark though.
I'm a bit paranoid about glugging noises as I remember my old Vauxhall Nova glugged before Mr Head Gasket left the building
Has anyone experienced anything like the above with their Idea?
I'm due a service very shortly, just wonder if it's worth getting the rad flushed and fresh coolant popped in.
Any comments would be much appreciated
Simon
Simon
