jimbro1000
Established member
I've often promised some pictures of my car on here but I've not been in a position to get any pictures until recently and then it came as a bit of a shock (to me at least) how much work was needed to get it looking fresh again.
As already mentioned a lot of my parts have been stolen recently and rather than just abandon the whole project I've decided to get on with it (it had been left with a friend to get it all together).
As you can see it isn't pretty but it turned out to be almost entirely superficial and the car is as solid as ever - it just needs cleaning, treating and painting.
I spent my free evenings over the last few weeks tackling all the rust I can get at and most recently actually fitting the panels for the front end - a job that has been put off for about 5 years. Another job that had been given to someone else to do and had been messed up. Thankfully they did all the necessary welding and it was only the attachment of the panels that started to go wrong and was thankfully caught before the panels were ruined.
The panels didn't quite line up on the body right and the fancy dzus fasteners were incorrect for the panel depth. I had to fork out for some new fasteners but now the whole lot is positively, mechanically fitted except for the bonnet which needs me to scratch my head a little more before I get on with it.
The front end is 3 panels that bolt together to make a single piece that can then be fitted or removed with relative ease (it is still a 2 man job but it only takes about 30 seconds to completely remove and only slightly longer to refit). The big issue is a lack of guiding points so you have to wiggle it around to get the fasteners lined up. I'm thinking of adding a pair of short pegs that are normally used as bonnet pins to take the hard work out of the job as I've been left with two holes in the nose that were cut for fasteners but lack the space behind them to work correctly.
The big headache is the cost - I have pretty much nothing to spend on the parts so I'm having to make do and use low cost improvisation where possible until I can scratch a more meaningful budget together.
I'll post more when I make a little more progress and/or get some more cleanup done!
