Technical  Gearbox
Technical  Gearbox
Chrisc1
Alloa, Scotland
Hi i have a 1.9 ducato 10 1999 camper i have been trying for 6 months to get a gearbox no luck as yet local garage charged me £3.500 to fix mine but made it worse now they don't want anything to do with it .are the gearbox that hard to get for it ? please help
You have not stated whether your engine is either a 1.9D, or a 1.9TD. The latter has 50% greater maximum torque, which could require a different box.
The following EBay advertisement is just one of the hits from an internet search,. https://www.ebay.co.uk/itm/167727370601
It supposed to be 1.9d but when son in law look underneath he said it has a turbo
The Fiat 1.9TD of that era was the model 230A3000, but from 2000 to 2001, the PSA DHY engine was fitted to Fiat badged models. As there is a slight possibility that you may have this engine, may I suggest that you investigate to confirm which engine is currently fitted. The engine may have been changed since original manufacture.
Thanks for that the garage that suppose to have fixed it i think they got a couple of fiat gearboxs and bodged it it whines in second now it didn't before thanks for your help I'll go check the engine
Hi again I might sound thick but where is the engine number i can't see it sorry
Not thick at all. Many struggle with such number hunts. Original should be on VIN plate , as well as somewhere on engine, but if engine has been changed......... May I suggest forum and internet searches. However if you can find the version "TIPO" on the VIN plate, then search for images of that engine to confirm that it is the same.
The engine number and model for my 2.8jtd are also on am adhesive paper label stuck on top engine, but paper is not permanent.
