my uno 1100 fire 96 model got a problem on the gearbox, both sides where the inner CV connects to the gearbox it leaks the gear oil. so ive changed the CV boots but still the oil leaks, can anyone help me please on what i can replace or do to stop the oil leak.
the other problem is with my distributor, the car came in with original distributor so now it went faulty and i to replace it with the new one, the new one comes with the regulator on the side at which if i connect the wires from the original regulator the engine do not start but if i bypass the regulator and use the original regulator on the side of the car near front shock it works but the problem is the distributor does not even last 3 months, can anyone help me with the drawing of wire-ring
