Ones is a psa engine the other iveco the diff and bellhousing is utterly different.
The gear housing is the same and you may be able to use some of the gears, shafts to fix your own but the ratios are different.
Short answer no, but if your stuck in the sahara or the amazon you might be able to bodge some parts to fix yours.
