why did only about half a litre of oil come out of the gearbox and only about half a litre went back in ? the book says two point four litres, which is a big difference. are we missing something ? thanks. pat
Sounds like you haven't drained it all out. You drained 1/2 litre out, therefore only 1/2 litre can go back in
When I've changed the oil in my gearboxes I always jack the car up higher on one side to tilt the gearbox towards the drainplug. I've always managed to fill up with approx. 2 - 2.4 litres afterwards. Are you sure your car is on level ground when you're draining/ refilling? Have you tried going for a run and then re-checking the level? Both of these might help.
Also, have you checked that your gearbox should actually have 2.4 litres? There's a few different types fitted to Unos but I only know that the early type has a 2.4 litre capacity. The later gearboxes may be different.
