General Galaxy s7 edge via Bluetooth and me USB
Edgie70
Hi all , quick question , is it possible to play my galaxy s7 edge via a USB cable into the USB input in the glove box in my t jet ?? Thanks
The USB port in the glove box must see a memory device and I don't think it will recognize your smartphone as it. There is a complete explanation of how the audio system works in the eLearn CD...
BRs, Bernie.
Had the same problem! had to put all of my Music onto a USB stick and play it through there.
Actually it's not that bad , the system even reads playlists and/or subfolders ! All is documented in the manual or eLearn...
BRs, Bernie
Thanks guys , tht i might be asking too much of the blue and me , cheers
In answer to the original question, If your Phone has an SD card inside it, then the B&M system will not connect your phone via USB. Reason being is that it see's it as 2 USB drives like your PC would (internal and external SD storage), and cannot decide which to access and catalog for playback.
Even without an SD card inserted in your phone, compatibility is a bit flakey.
Best just to pop your tunes on a USB stick and play them from that.
