A Aerosea New member Joined Sep 16, 2022 Messages 2 Points 1 Location Brisbane Sep 17, 2022 #1 Ducado 2010 fuses for number plate light? Not seen on any manual or online.
L LandyAndy Member Joined Aug 16, 2022 Messages 122 Points 74 Location Hertfordshire Sep 17, 2022 #2 There is no fuse for just the plate light so assume it will be powered off side light circuit. So either under dash fuse board F12 or F13 7.5amp. Are all other lights ok? Upvote 0 Downvote
OP OP A Aerosea New member Joined Sep 16, 2022 Messages 2 Points 1 Location Brisbane Sep 17, 2022 #3 LandyAndy said: There is no fuse for just the plate light so assume it will be powered off side light circuit. So either under dash fuse board F12 or F13 7.5amp. Are all other lights ok? Click to expand... No, parking lights out too Upvote 0 Downvote
R rayc Established member Written a review Joined Mar 12, 2009 Messages 1,098 Points 324 Location Wimborne Sep 17, 2022 #4 The sidelights fed from the Body Control Module. There is an internal fuse that should reset when the fault is removed. Upvote 0 Downvote
D Davegt79 New member Joined Apr 4, 2024 Messages 7 Points 3 Location Belfast May 25, 2024 #5 LandyAndy said: There is no fuse for just the plate light so assume it will be powered off side light circuit. So either under dash fuse board F12 or F13 7.5amp. Are all other lights ok? Click to expand... Yes all working. Upvote 0 Downvote
D Davegt79 New member Joined Apr 4, 2024 Messages 7 Points 3 Location Belfast May 25, 2024 #6 Aerosea said: No, parking lights out too Click to expand... All fuses are ok. Upvote 0 Downvote
D Davegt79 New member Joined Apr 4, 2024 Messages 7 Points 3 Location Belfast May 25, 2024 #7 rayc said: The sidelights fed from the Body Control Module. There is an internal fuse that should reset when the fault is removed. Click to expand... Many Thanks. Upvote 0 Downvote
