Technical  fuses /lights
boiler man
2008 bravio 150 sport reported a stop light out on the dash ,replaced it and checked it all ok, then parked back on drive and then dash reports stop light and side light failure ,replaced side light but no power at the light socket
but other side light works fine ,are they on seperate fuses?
and how do i access fuse bank under glove box
I do believe that the fuses are seperate for left- and right-hand side light units.
Accessing the fuse box behind the glove box...well I wish I knew too!
have had exactly the same problem twice... when replacing stop lamp, the sidelights fail...dont think there are fuses for the rear lights, i think they are controlled by the canbus system...
anyway after swapping all bulbs about numerous times, they just decided to work again..:confused:
