Technical Fuse for internal fan
dougdotcom
Hi, my fan dose not work on any setting, is there a fuse for this, I have had the cover off under the steering wheel and tested all the fuses there but are all ok. then took the cover off in the engine bay but did not test these before I asked on here as it could be a common problem that someone can point me in the right direction. It's the 2011 model.
Many thanks. :)
Many thanks. :)
Hi Doug did you get to the fault of your heater problem ,I see you didn’t get any replies ,I have the same issue with my 2011 fiorino so if you have any remedies be much appriciate some help in fixing
