General  Front headlight bracket
apinnard
Kettering, Northants
If you look under your bonnet at the front headlights, there is a small plastic bracket that holds the headlight to the car. Mine has snapped and at the whole light unit is moving around and could fall out!
Does anybody know where I could buy a new light unit to fit myself? Fitting it seems pretty easy but I am at a loss as to where to look for the part.
-Alex
Oooh also; does the Marea have an internal temperature reader? I ask this because when I set the climate control to say 20 degrees, the car heats up and goes above this temperature, it doesn't stop at 20! I think either the climate control is b0rked or the thermometer thingy that tells it the inside temperature is dirty. Any ideas if and where I can find this device?
